scenes changes does not take effect
Nicklas Simberg shared this problem 12 years ago
I hade some old scenes I executing in different rules. all have been working fine but after investing in a few new devices and added them to the box the scenes still work but the newly added devices does not change accordingly to the scenes.
However if I delete the old scenes, create a new one the new devices does work.
same thing happened when i updated the blind with a new position in the scene. Did not take effect until i deleted the scene and created a new one
Replies (8)
after you modify a scene please click Save and then Synchronize.
Also in Rules creator after every modification click Save and Synchronize rules.
Hrvoje
of course i have done this. i guess this is related to https://community.zipato.com/responses/new-scenes-not-working
To be sure i am not wrong i did a new test today when i did get a new Z-wave plug.
Added the new z-wave device, named it properly and changed made changes to how it should behave in each scene. (i saved and sync in every step)
To be sure i also re-synced the rules
When i run the scene the new device does NOT follow the configuration in the scene.
The problem you mention https://community.zipato.com/responses/new-scenes-not-working was resolved. Please contact us on support@zipato.com with your user credentials so we can check the status of your ZipaBox.
Hrvoje
Same problem for me. New devices are saved in the scene but there is no effect when the scene is executed !
I mailed the support a few days back with information but not had any feedback so far but only been a few days so we will see with time.
Hope it does not take to long time since my scenes are now screwed up and i need to redo them to get everything working as it should. Waiting on response before i delete them and recreate them so you have something to test on
yesterday the box crashed/hanged (not responsive) so i had to pull the plug and it booted up again. It seams that did the trick för the modified scenes and the new device suddenly start reacting to the scene changes.
Don't see how that should be needed for a scene change
been in contact with support and they have solved the issue.
