Schedule weekly don't work ! ! !
DaBoss shared this problem 13 years ago
One more bug . . . impossible to use scheduling weekly if i don't select several days !!!
/a9cbc7fb93bdd6ff119d861aafab2d25
I wan't to make action only on working day but not work ! ! !
Replies (11)
I'm not sure what exactly is problem. Weekly scheduler doesn't work at all or it just doesn't work when you set working days? Does it work for you in any case?
As i say in my screenshot if i unselect one day then the schedule no more work ...
Had to make more test but if i sélect all or only one so it's working well
I cant get weekly schedules to work at all now. Worked for a while then just stopped working.
Updated to latest firmware version, re-synced rules but unfortunately no joy.
Nenad, here my action in order to reproduce the problem...
Purpose is to create a simple send mail at spécific hour every working days...
So :
- Creation a new rule . . . WHEN
- Condition is sensor "scheduler"
- Action is send message
- Click configure on scheduler
- Start date is today, the of rule's creation
- Configure hour in the future, if it is 14h00 put 14h15
- Check Repeat and Edit . . . then select all working days . . .Mo, Tu, We, Th, Fr
- Save and Save.
- Synchronse rules . . .
And wait . . . but nothing append . . .
If you edit again to check and add Sa, Su and change hour to a future execution . . . and re-sync rules . . . it work well . . .
Final purpose is Open/Close my blinds automaticaly but at the moment it's not possible due to this bug.
Do you reproduce this error ?
Still trying to make it working but no result...
Vraiment décu de cet box, en un mois avec 5 module pas moyen de faire une seule fois une action sans un bug ! ! !
I am exactly experiencing the same problem. The schedule doesn't work if REPEAT flag is set. If you remove the repeat the same rule works!
yes, it's obvious now that we have a bug here. We are already working on it and it will be fixed very soon.
Could be closed
Still not working in release: 1.1.38 2/2017
Thomas,
I have several schedulers and they work fine with some exceptions when there are server or internet problems. Can you show me the configuration of the scheduler that is not working and the rule you are trying to fire with it?
Still does not work for me
