setup the level of the green light
Guest shared this idea 13 years ago
The green light bright very well :). If could ne nice to be able to define its level in the configuration panel.
Replies (19)
In another issue, I suggested to be able to set-up the level of the green LED : http://community.zipato.com/responses/setup-the-level-of-the-green-light
You can vote on it!. I think it is usefull to have the light on but for now it is bright enough to see during the night in my appartment :)
Voted!
thanks ;)
What do you think? If it is possible to decrease the light, do you need to switch off?
Decrease the light would be fine
We can make it up to 3x less bright by doing PWM on it.
At 4x it begins to flicker.
At 5x it hurts.
Your votes please. :)
I prefer to avoid flicker :) so 3x less would be fine :).
Is it possible to anyone to set-up that in the general settings: FULL; 1/2; 1/3 ?
No flicker please!
What about to add in general setting also the switch off? :)
thank you
Keep it as it is.
Rather see a different color flashing when firmware update is available.
So there is no need for me daily checking dashboard.
I've seen in the last firmware update 0.9.96, you did something about it. Is it available on the GUI?
Not yet.
We have to update a few things on the server.
Patience, please. :)
ok :)
New option (Green LED brightness) is under General settings -> Box settings.
Select desired brightness and save. And don't forget to synchronize the box :)
Thanks :), I've seen the list, but I'm not at home :), I will see that tomorrow.
Fantastic!
Thank you so much
Adjusting the brightness of the green LED does not work for the latest version 0.9.7.3.
With the 0.9.9.7.4 firmware, the brightness level seems inversed :
0% --> 0%
25% --> 75%
33% --> 66%
50% --> 50%
66% --> 33%
75% --> 25%
100% --> 100%
since 0.9.999.3.a the green led can be set to 0% but in real it s only dimmed.
My Zipa with the release 0.9.999.3.a the green LED is always turned on whatever value is set in the configuration.
In addition, the minimum level is 5% while I would turn it off.
