SOMFY RTS ERROR
Francois Bontemps shared this idea 10 years ago
Hello everyone,
I have 433MHZ module and somfy RTS roller shutter :
With this procedure :
Inclusion with Zipato Controller (433Mhz protocol)
1. Prior inclusion with Zipato controller your Somfy RTS motor needs to be put into the learning mode
2.
To set the device in learning mode press and hold reset button on the
backside of Somfy Remote controller until the RTS motor jogs shortly
down & up
3. Start inclusion of Somfy RTS on Zipato controller via "Add new device" button
4. Find "Somfy" brand/logo and select Somfy RTS in the "Add new device wizard"
5. Click "Continue" button in "Add new device wizard"
6.
After you click the "Continue" button your Somfy RTS motor will jog
shortly down & up to confirm inclusion with Zipato controller
My problem is that roller don't confirm with a jog ma pairing but zipato control board write module find and it is OK for him ??!! I try to continue and put time for up and down --> don't work and try in normal or reverse --> don't work .
After few minutes , roller jog to say that it go out of pairing mode .
So my opinion is that zipabox don't send information to roller that it found it .
Have you an idea ?
Thank you for your help,
F.B
There has been a discussion on this recently, and I also suffered from the same.
You have to update the firmware of your zipabox (with beta), which will update the 433 module firmware, and you'll recover the somfy rts pairing & control.
Cheers
This was resolved in another post => https://community.zipato.com/topic/somfy-pairing-problem
Closed!
