Stopping Hostmann HRT4-ZW wall thermostat from changing state of virtual thermostat
Hello, all
I made a virtual thermostat with a the horstmann HRT4 as input device to set the temperature.
That is al working fine.
The problem is that the HRT also gives a Mode change to the virtual thermostat. It turns the virtual thermostat from heating to off if the internal thermostat of the HRT4 drops below the set temperature of the HRT4. I don't want that to happen, because i want to control the set temp. from a rule and smartphone without the need of setting the thermostat to heat mode.
Hope you can help me,
Stefan
In device manager setting the virtual thermostat_heating_level state to master and hard reseting the box didn't help
Well, in the case you only want to use the thermostat as temperature measure, remove it from input and add it as temperature device. Also, don't forget to add it as output thermostat so it received virtual thermostat setpoint
It must be used as output device in order to receive changes in the virtual thermostat program. If u use it as all 3 devices (input, output and temperature, it should work as needed.
