Synchronization Failed
Marios Papazachariou shared this problem 10 years ago
I have a problem with the synchronization of the Zipabox.
When pressing "synchronize" keeps giving the error "synchronization failed"
37ece8eda3fc6d161edf08f935f31c59
Replies (8)
Try this:
Disable all the rules >> then sync. >> then turn one on >> sync >> etc to see if a rule causes a problem.
I have not rules . My zipabox is new . I deleted all the devices and i have the same problem
Are you behind a firewall? Make sure all of the required ports are open. Had this issue... IT moved the zipabox to the DMZ and synch worked again ( a commercial application).
.... just disconnect from mains, wait 20 sec and start again. Works for me very good.
Dear Marios,
please open a Ticket at support.zipato.com and provide us with the serial number of your Zipabox. Thank you in advance.
Pero Zovkic
I have used all test but nothing , the problem is the same.
The problem resolve when downgrade the firmware (0.9.999.6) but some devices not supporter .
When upgrade the firmware at the last Beta (NEWEST) 0.9.999.8X4 the problem come back again.
I have had the same "synchronization failed" for over a week now. I have tried.
1) Latest software.
2) Official software.
3) Previous software.
4) Deactivate all rules.
5) Restart the box.
6) Power the pow off and on.
Is there anything more I should try?
I have had the same problem before, but deactivating the rules (and deleting the faoulty rule) made the synch work then.
Open a ticket.
Thank you, I will
