Tamper alarm set of occasionally on my Fibaro motionsensor
Got this message a couple of days (not every day and at different times)
No one has been tampering with the sensor!Details:
Message: tripped
Partition: Skalskydd
Armed: DISARMED
Tripped: true
TripType: TAMPER
Zone: Zone 4
Zone UUID: e6874e68-a614-43b4-a4db-105d70adddd4
Endpoint: Ljusrelä-inne
Attribute: STATE
State: MOTION
Cheers.
I now think this is the message i got because the battery was getting low?
I received such a Tamper alert when my Fibaro sensor moved a bit (a vibration in the house). The G-Force sensor detected it as tamper. I disabled that feature via the configuration of the device.
Hello Lars,
Leonmeijer is right. Fibaro motion sensor FGMS-001 has a Tamper shock sensor, so any vibrations will activate it. In order to avoid constant Tamper alerts you can change the Tamper sensitivity.
Go to Device manager, select the folder Fibaro FGMS-001 motion sensor, go to Configuration and change G force tamper sensitivity. Changing it to 0 will make the Tamper inactive.
Hrvoje
Hello Lars,
Hrvoje
Hi Hrvoje,
It can be a solution to deactivate the tamper... and wait for the device to wake up and get the new parameter. But wasn't there going to be an option "maintenance" in the alarm panel, for example, to change the batteries or manually wake the device up without tripping a tamper alarm ?
Best Regards,
Damien
Domotique-Store.fr
Hi Hrvoje,
Best Regards,
Damien
Domotique-Store.fr
happened to me too. some seconds ago.
walking in front of sensor (sensor fixed to the wall at 2,20mt).. with motion it detected also tampering.. but obviously no one tampered it.
Something wrong in the sensor configuration?
Have changed/lowered the tamper sensitivity, problem solved!
