Thermostat broken: need to save twice to get it work
xmeslin shared this problem 13 years ago
Same issue is still not fixed :Steps:
Thermostat works
I change the weekly timezone
I save
On the dashboard the new temperature appears (in change are done for the current time)
I manually change the temp : it works
I click on run program and it doesn't change the temp. It stay stuck to the manually set temp
I need to open again the thermostat and click on save to have a working thermostat
UP. can you do something I still have this issue.
Look at my thermostat Parents. I just changed the night temperature to 17°C instead of 18.2 and now it doesn't work anymore. When I put it on run program it stays stuck to a manually set value.
Please fix it. We are told to be patient but nothing is coming up Ah yes you are selling thomson stuff and other extension but the basement is still broken.
It has been 6 months we are trying to debug but feedback on issue we report is still very limited. Same as firmware update. In a debugging phase I would expect a much higher frequency
Bug still there. Can you make thermostat usable please ??
Have a look to my thermostat parent. You'll see it doesn't work
Bug still present on my box. Can you log to fix it please ?
