Thermostat : when manually set the temperature doesn't move to hold until
with the new GUI (which is great BTW) when I manually set the temperature, the mode doesn't move to hold until next period but it stay stuck in program mode even if custom is reporter in the menu.
Tks,
Do manually set the temperature on web interface or by using input device?
on the web interface
and if I put manually hold until and then click on program, the temperature is not changes to the programmed value.
We will take a look at your thermostat because we can't reproduce such a behavior with thermostat setup in our lab.
ok you already have my username / password. feel free to look at it. Please do it this afternoon because I will have to fix it before the cold evening.
thermostat not working is "salle".
Tks
Tks
and the led are blank : heating / off. The one of the thermostat Salle is green because I just touched it.
Can you please try it now. I found and corrected bug with thermostats without cooling.
And BTW thermostats Extérieur and Garage, they don't have any outputs at all. Did you created them with inputs and then deleted them? Do you even use this two thermostats? Because they are useless without output devices.
ok cool. yes it works.
devices.
No. Actually I created them for several reasons:
1) it is the only (?) way to get decimal temperature on the iphone app
2) I can get all temperature as soon as I log. Otherwise I have to click on the temperature button on all thermometers because default value is humidity
BTW, I cannot turn off the exterieur thermostat but since it is a fake thermostat, it's not important. Just for info
devices.
