Today Alexa stopped to work with zipato ;-(
Klaus G shared this problem 9 years ago
Today all http switches and devices stopped their work ;-( To my surprise all devices are shown as offline in the alexa website. I can still change the state via the zipato-app or the web interface. And the echo dot works fine, too.
Is that a problem on the amazon side or could that be a problem with the zipato skill? It used to work flawless for quite some time and now it stopped ;-((
Any idea is appreciated
/862e3c4923f74f37e4e96196215f597a
Replies (23)
no sorry, still working fine here. I have had this issue before though, and can not tell you if its Amazon, Zipato or something in between that causes it. Zipato still worked via app and rules, Amazon still worked when asking questions, just could communicate with Zipato system. It happens, and for the price I expect some minor issues every now and then.
Try running another discovery process and rebooting your systems, Alexa and Zipato.
Das Problem hatte ich auch, habe dann den Skill deaktiviert und beim aktivieren kommt nur noch eine Lange Fehlerliste
Yes ... same here. Doesn't work. Also try to deactivate and active skill. Long reply with status 500. Please fix. Thanks and best regards.
Same here. Not working since yesterday. Alex says the devices do not respond.
Hello Everyone,
We have investigated the issue and resolved it.
Everything should be working now. If you are still experiencing problems, please open up a support ticket so we could help you out.
Cheers,
V
Thank you Vedran, everything is fine again.
Cheers
Klaus
Mine is unresponsive tonight...
Alexa works by itself.
Z ipato is fine too
Alexa and Zipato = "device is not responding"
Mine too...
Working yesterday morning (15/12/17) but stopped at some point during the day.
Alexa works for everything else but for Zipato says "Hmmm, tree lights is not responding" when i try and turn my christmas tree lights on/off.
Me too - Since yesterday at the same time alexa and zipdato doesn't work together anymore. :-(
hello I think that has something to do with the new feature, Alexa Group.
Yep. My Alexa has stopped working since yesterday too.
0
Alexa service is currently unavailable. Soon it will be available again.
Quite sorry, Alexa is down again ;-( Do you have the same problem and is anyone working on this problem?
Me too. Alexa with zipato is down again :-(
As this is such a critical issue for many, please can we have some clarification on what you mean by "soon"?
As an aside, it's not clear from the mobile view at least whether you work for Zipato or not, you should fill out your profile a bit at least.
I can't operate most of my house, and all I have is someone posting 2 days ago saying "soon". Not really good enough.
Agreed - this is very frustrating. Probably 90% of my interaction with my Zipabox is through Alexa and the fact that it doesn't work has made my smart home dumb.
The same problem with our Zipabox; latest firmware. Reboot, enable/disable skill, nothing fixes it at our end. Any idea when this will be fixed? We use it to enable our disabled son to control devices in the home, so it’s quite a problem for us. Be good to know when it will be fixed.
Thanks!
Hello all,
please try the following steps:
- connect to http://alexa.amazon.com/spa...
- afterwards navigate here:
/cRzO68l3XCOf+PwsUDLukr6KIAAAAAElFTkSuQmCC
- select:
If this won't be working, try 'Forget all', and discover again.
I've tried it in our testing lab and it has been working without any issues. I'm awaiting the feedback of you guys.
Stefan
The Problem is still the same
I manually deleted all my Zipato items but they wouldn't come back, so I've just done a 'Forget All' (which also gets rid of my other devices) and a rediscover and now the Zipato things have come back. Maybe this is an Amazon issue and not a Zipato one.
Cheers,
Steve
Hi. Has suddenly started working again: we didn’t have to do anything. Hopefully this is a permenant fix?!
Yup, my Devices are working also again!
I can't believe that but it doesn't work again. What is that for a bad Service? Three times in less days and no information.
Each time there has been a problem with alexa/zipato I have always been able to use zipato via tge zipato app to control devices. Now I can't use alexa for zipato and also can't control any devices through the zipato app. Please help!
alexa/zipato stopped working. I'm using Fibaro HC2, there all is working fine. only Alexa doesn't find the bulb anymore
