Turn off Fibaro Wall plug in a Scene
Jeroen Stive shared this problem 13 years ago
I've created a scene to turn off all the light when i'm going to bed.
In this scene i use a:
Fibaro FGD-211 Dimmer set to 0%
Fibaro FGS-221 Dual Switch set to off
Fibaro Wall Plug set to off
The dimmer and dual switch go off but the wall plug doesn't go off, is this a known bug or should it work?
I've checked and the setting is on INACTIVE, so thats not te problem. I've created the scene and added the 3 devices at once, so the sync has to went fine, also the wall plug is added to several rules and than it works fine.
I will try to re-add the wall plug tot the Zipabox to see if that work's
Did you synchronized after editing scene?
