Unable to add WGR800, joint failed
I am trying to add a new WGR800 on the Zipabox with RF433 interface. (REM: chacon modules are working on the same interface).
Each time I start the detection the countdown goes down to 0 and ends with a "joint failed" message.
I have tried the following sequences:
- Simply start detection
- Remove batteries for 1 minutes in the WGR800, thne start detection, then add batteries (took 10secs)
- Same as above but also pushed the reset switch after having installed the batteries.
Any idea
