Unable to include Fibaro FIBEFGKF-601
acteck shared this problem 8 years ago
I allways get the
Manufacturer_specific_report not received
when I try to include the keyfob. Inclusion in my ZIPATILE works fine, but in the ZIPABOX it is not possible. Is there a trick or a timing problem?
Replies (9)
0
continue pressing the inclusion button while including, afterwards it should be recognized properly. I'm awaiting your feedback.
Stefan
0
you know one has to press 2 buttons same time and then another one to wake up the keyfob. So inclusion did not work, even when I try to repeatly wake up the key fob. With the Zipatile it worked, but not with the box. Any other idea?
Best regards
Andreas
0
Hello Andreas,
would you like your controller to be upgraded to the latest beta firmware which contains several bug fixes which are involving Fibaro devices as well?
Stefan
0
Ok!
Von meinem iPhone gesendet und deshalb ganz kurz.
Grüße
Andreas Tecklenburg
0
Hello Andreas,
try it again now. I'm awaiting your feedback.
Stefan
0
Thank you.
Will try at weekend!
Have a good time!
Andreas
Grüße
0
also with new firmware same error. Inclusion ends after “Configure device” with same error.
Andreas
0
Hello Andreas,
simply install the latest beta on the Zipabox of yours, which can be found in the controller settings menu on the Web UI, afterwards it should be working accordingly again.
Stefan
It does still not work. Manufactor specific report not received. Newest Beta installed.
Grüße
Andreas Tecklenburg
Am 04.07.2018 um 14:45 schrieb Zipato Support Portal <mailer@3plus.hr>:
