Update sensor and actuator endpoints with Room name automatically
Dan OC shared this idea 9 years ago
I would be a great help if when adding a decide, for example a multi Sensor that you are asked to select a room. This room is then added to each endpoint of that multi Sensor.
At the moment I have to manually rename all the endpoints so I know which motion sensor is in what room in the rule creator
Like it! +1
(also the renaming... which by the way, on the zipatile assistant is not working properly)
I like it, however there could be people who wouldn't like that. I guess we can vote here. I have a specific convention to name devices, then the endpoints I want to be "alexa friendly" I rename them with Room + Short description.
