URL for getting-setting values
Guest shared this question 10 years ago
I am trying to avoid using the old application but I still cannot find al the information I need in the new application. For example; I want to update the value of a virtual device. In the old application I can copy the url for doing this via the "Edit endpoing form". In the new application I cannot find this information. Am i looking in the wrong place?
Alexander
Oldest
  • Oldest
  • Newest
Never mind. Found the answer. If you drill down in the device manager you will find the url.
Can you tell me where you found the URL ? I'm in the same situation, but still have not found the key !
af26d2b5e4d23908c0ad3888bfeb882e
27e48b16902b3003a6e36bb6666caeb7
Thank you Darkwing.
It's OK for virtual meter. But I'm also searching for virtual switches. There should be a URL to set the virtual switch to On or Off ?
Thank you for this.
I was misled by the "http" in the name...
Why is it not possible to add this function ? Thus there is a simple switch which can be set either by the device browser or by an external application ?
Hello Ivan,
Good to hear.
May I suggest you to give possibility to simulate monostable (push button) virtual switch ?
May be there is a workaround for that, but at the moment, I set a rule who detect the switching to On, do what must be done and reset the switch to Off. A push button would be more elegant.
BR
Alain
