Variable is not saved
Kim T. Nielsen shared this problem 13 years ago
When I try to use a variable (a new variable called f.ex. COUNTER) in a rule, then it is not working and the variable is not saved, so, when I come back to the rules creator, all the places where the variable was selected is now empty, and it is not possible to select it - the variable list is empty.
Problem solved.
Problem solved.
