Virtual Meter configuration not saved
In Progress
Looks that Virtual Meter configuration Names not saved even if I put new names, save and syncronize. After I reload web page it stay on original state and my changes are lost. This causes that I cannot use virtual meter variables in rules.. Please fix this.
Zipato support answer:
This is an issue related to an current UI version which will soon be replaced by a new one. With the current UI version, virtual devices UI data is no longer being saved as the new UI will work on different principle. For that reason this will not be resolved until the release of the new UI. It should be released in a 2-3 weeks from now.
I must ask you for a little patience until it is released.
Hello
I have a ticket open since july the 9, and the answer 2 weeks ago is
Hi Nicolas,
This issue is no longer being debugged with the current UI version
because new UI will be released if not by end of this week then ext one
for sure. With the new UI this issue will no longer be present.
On the new UI we are using different data in order to save and show virtual devices.
Milan
It's very long to wait.
Hello
Hi Nicolas,
Milan
This is still an issue at newest UI ! Please fix this!
I still have the same problem. I need this function :-) Can this problem be solved quickly?
Is there any news?
Is there any news?
