zipabox 1 and new app
dear zipato team -
i have the zipabox 1 and i am using the old app.
clear questions :
1. can i use the new app ?
2. how do i install it and make it work ?
3. will ALL devices, settings and routines remain ?
thanks for a clear answer.
best, rakesh
in general ZipaBox1 is not supported fully on Zipato V3 platform (new app) since it has a problem with Z-wave module when its firmware is upgraded to the latest beta version (fw > 1.3.93+ is reqauied for V3 platform).
We are working on solving this issue and after it will be solved, you can transfer from V2 to V3 platfrom by following this procedure:
1. Unregistered (Clear owner option) your controller in v2 platform
2. Create v3 account at https://my3.zipato.com/zipato-web/app2login - it is possible to use the same account from v2
3. Under my3.zipato account create System
4. Add server (controller) from step 1 to the System as a Master server - NOTE: Master server can be any Zipato controller but NOT ZipaBox1
5. Add another server to the system as Slave server (Multisever license is required) - optional; NOTE: Slave server can be any Zipato controller.
6. All real devices from v2 will be presented in the System
7. All virtual devices, Scenes, and rules should be re-check by user and re-created if necessary (it is not supported transfer virtual elements from v2 to v3)
