Zipabox 2
I'm still using my Zipabox 1 and, at the moment, there seem to be issues with the Zipato servers so nothing is working.
If I transfer to my Zipabox 2 will things work through my LAN when there are problems with the Zipato servers?
Hi David,
if there is a problem with Zipato server your rules in ZipaBox (both 1 and 2) should work properly. If you connect your mobile app in the same Wifi network as ZipaBox, it should be possible to control your devices by mobile app even if there is no internet connection at all.
Dino
Hi David,
Dino
Well I've been using a Zipabox 1 for 6 years and I never have any control when Zipato have a server problem.
Hi do you have to check the "stay offline" option. Under V3 with this option all Rules works and also a control via App is possible.
Hi David
if Zipato server has a problem, rules should work fine and if you connect directly by mobile app to your Zipabox (using the same network -> don't need to use internet), you can control devices manually.
Hi David
I use the web app.
I use the web app.
