ZipaBox and Static IP
What about the possibility to assing to the ZipaBox a static IP address ?
Consider that there can be some problems to DHCP server in a network and without it the ZipaBox wuold be isolated.
TIA
You should set the static ip directly in the DHCP config of your bridge.
I think that when you configure it with the MAC address of the zipabox, it shouldn't cause any problem.
