Zipatile keeps logging out
NLondonLem shared this problem 8 years ago
Hi I have a Zipatile with the latest firmware/software installed as at 24/3/18 and unfortunately after I log in the device logs me straight back out and keeps doing this. I can no longer use the Zipatile.
If I log in to the app it did the same until I reinstalled the app. I have checked and the username/password is correct.
Try to upgrade the Zipato app from App Repo.
Thank you for swift response - just worked. Disappointed that this bug got through testing. The homepage has now lost all the favourite apps and I have had to re-set these up. I am disappointed as I would like to invest more in my home automation set up but feel that this is still a 'beta' product.
Upgrade of Zipato app shouldn't remove your favorite apps from the main page. Maybe you were cleaning the data or cache from the app...
Thanks. All I did was press upgrade, nothing else. 100pc certain did not clear cache etc.
You are right i had experienced same symptoms several times after update. All my shortcuts from home screen disappeared after update...
Please upgrade upgrade Zipato application to v.2.3.2. This version doesn't have this issue any more.
