Zipato Mini Keypad with zipatomini
Hi all.
I'm considering to buy a Zipato mini, specially to control the access to my apartment while I'm away. In that way, I'm considering to buy also the Door/Windows Sensor and the Mini Keypad with RFID supporting a total 5 RFID Tags.
As far as I know, with Zipato mini you have by default a license to support up to 5 devices. In this scenario, is each RFID Tag considered a single device (so it would be 7 devices: 1 Sensor + 1 Keypad + 5 Tags) or will this setup consider only 2 devices?
Thanks in advance
Hello Joao,
I think it will be much easier if you use Alarm zones and Alarm partitions to configure your "Alarm" since you can find there almost all option that you have mentioned.
Hello Joao,
Hello Joao,
RFID Tags you mention will not be counted as devices on Zipamini. The setup you mention will be counted as two devices.
Hello Joao,
Hi Antonio.
Thank you for your fast reply. I've a few more questions:
1 - is it possible to configure multiple actions like:
If Door Sensor opened then
Beep Keypad
wait 3 seconds
If Keypad not disarmed then sound an alarm
2 - Do this system keeps a log accessible by the mobile app where I can check the events registered by the devices?
3 - In your point of view, what is the number of devices I should consider buying a Zipato instead a Zipamini?
Thanks in advance,
JA
Hi Antonio.
Beep Keypad
wait 3 seconds
Thanks in advance,
JA
1. The rfid reader is battery operated and is not listening for commands / requests from the controller (Zipamini). So you cannot make it beep like that.
