Big problem with a FGR221 - ver. 2.1
Not a Problem
Hi to all,
I have a big problem with a Fibaro Roller shutter FGR221 - ver. 2.1
I can't do an autotune to make sure that the percentages are correct.
In fact, after the inclusion in the system, does not double cycle of ascent and descent, so if I bring the shutter to 50% does not match the 50% real.
I have tried in various ways but I did not succeed.
I have 4 modules installed on roller blinds.
Thanks to all
Does 0% or 100% work perfectly ?
The Fibaro modules do not work properly with engines with electronic stops. So you can not use % but only use Open/Close.
When you put 50% in value does the blinds stop a the same position every times or stop at different position ?
