Big problem with a FGR221 - ver. 2.1
Alberto Parma shared this problem 12 years ago
Not a Problem
Hi to all,
I have a big problem with a Fibaro Roller shutter FGR221 - ver. 2.1
I can't do an autotune to make sure that the percentages are correct.
In fact, after the inclusion in the system, does not double cycle of ascent and descent, so if I bring the shutter to 50% does not match the 50% real.
I have tried in various ways but I did not succeed.
I have 4 modules installed on roller blinds.
Thanks to all
Oldest
  • Oldest
  • Newest
Replies (5)
Does 0% or 100% work perfectly ?
The Fibaro modules do not work properly with engines with electronic stops. So you can not use % but only use Open/Close.
yes, when is 0% is open and when is 100% is closed...
When you put 50% in value does the blinds stop a the same position every times or stop at different position ?
always stops at the same position ...
Milan Gulis wrote:
Hello
We are using FGR-221 in our lab on actual roller blinds and it is working perfectly.
Your problem is probably related to your roller shutter motor ( check if it is compatible with FGR-221). They usually have options to set start and end position, but for that you should look in instruction manual. Also check in your Fibaro FGR-221 configuration that parameter "Turn off shutter positiioning" is set to "Turn On positioning".
where I can see if the motor is compatible with the FGR-221?
