Schlage BE469NXCAM619
Wojtek T shared this question 13 years ago
Is anyone using the latest door lock from Schlage?
http://www.nexiahome.com/products/productdetail.aspx?model=BE469NXCAM619
It's Z-wave but intended to be used with their service (Nexia), people on Homeseer forum report some challenges (http://board.homeseer.com/showthread.php?t=158715)
Will this unit work with Zipabox?
Replies (6)
I went to Home Depot and purchased one of those door locks. Association happened without any surprises, I can see SECURE_KEYPAD_DOOR_LOCK as a switch and a sensor.
I can control the lock by toggling the switch however I do not get any feedback if I use a knob or a key to unlock/lock the door. Should I move this post to "Problem" section?
Anyone
Greetings,
To the best of our knowledge, this particular model does not report door lock state when operated manually.
And i recommend that you open a ticket, it seems that your door lock was not identified correctly.
In another discussion i already pointed you to discussion for other forums clearly stating that this lock reports its status. I am not sure if the locks reports or if you have to queerly it but it simply works
I just posted an answer about my success in this thread...
https://community.zipato.com/topic/schlage-door-lock
