Hot Water Tank
Is there any way to use a Virtual Thermostat to Control a hot water tank. I have a Fibaro universal module with a temperature sensor on the tank.
The problem is I need to heat the tank to 65'C
I have done it with a simple rule
seems to work well
seems to work well
Hi Graeme
sounds interesting to me but how do you measure water temperature in hot water tank? Could you post a Picture how you installed the sensor to measure the water temperature?
Not sure what you exactly want to achieve with a virtual thermostat but I imagine you would like to run heat up if temperature is below a certain temperature and only during night? This could be done simple with a rule...
Beat
Hi Graeme
Beat
Do you get readings at all? As far as i know the universal sensor is not compatible with digital but with analog sensors
