Problems with my RF 433 module connecting CoCo devices
Rens shared this problem 13 years ago
In Progress
Thursday I received my 433 mhz module and I started right away.I do have some issues with it and hope you can help me with this.I have the following devices from KlikaanKlikUit ( Coco)But it seems like the module doesn't recognise all devices correctly.I have the following remotes:
http://www.klikaanklikuit.nl/shop/producten-1/?type=66
AYCT-102
ATMT-502
AKCT-510 keychain
AWST-8800AMST-606
And I have 4 of these switches for electronic shutters/screens
http://www.klikaanklikuit.nl/shop/producten-1/ontvangers/zonwering-schakelaar-asun-651/
ASUN-650
And I have 3 of plugin wall switches:http://www.klikaanklikuit.nl/shop/apa3-1500r/
APA3-1500R
And one behind wall switchhttp://www.klikaanklikuit.nl/shop/catalogsearch/result/index/?q=awmr-230&type=75
AWMR-230
Ok let me tell you that I can use the AYCT-102, AKCT-510, AWST-8800 remotes for joining with the
following join devices:
coco key chain remote control
coco magnetic contact switch
coco transmitter for behind wall switches
coco wall switch
but none of the appear as a "power switch" on the dashboard. I don't know if this is normal behavior but I would like to be able to control them directly from the dashboard.
I do see them appearing in the rules creator under endpoint control.
The ATMT-502 remote, AMST-606 (magnetic contact) do not want to join on any of the coco devices listed.
I really want to be able to control my electronic shutters/screens through the ASUN-650.
But when I try to join them with a channel from example the AYCT-102 remote on device coco receiver for electronic screens I get instantly Join not successful.
Yours Sincerely,
Rens Hoekema
i have ASUN-650 also, but i have a question, in dashboard Fibaro roller shutter has a percentage slide for open or close blinds... but with this device i can't find it... how i can choose percentage from mi phone, for example?
regards
I connected a few coco-devices (even motion detector), keyfob, light bulb, socket plug... But connecting the wall switch AWST-8800 is not working. Not even when holding the switch next to the Zipabox.
I was able to connect the switch directly to a coco actuator (so switch is working properly).
Any idea why it doesn't connect to Zipabox?
Did you find a solution to connect the AWST-8800?
I have the same problem with an AWST-8802...
I also have problems with the COCO ( klikaanklikuit ) AWST-8802 . It does appear in the Device browser but whatever I do: I do not see a switch. And I cannot switch it on/off in my device browser..... Anyone??????????
Added screendump
In the screendump (look at attached file) you see the other switch (named HOEK STATE TV) WITH possibility to switch it on or off. But my COCO AWST-8802 is visible but NOT switchable. No On/Off switch
