Problem to address Remotec ZRC-90 Buttons
HalloI have bought a ZRC-90. The inclusion process was successfully and the device manger recognizes it as ZRC-90. However, when i create a rule and want to address one of the button it does not work. I am not able to choose among button 1-8. Instead i only can choose among the options: sensor state true or sensor state false.
What I am doing wrong?
Do someone have an advice?
the buttons should be located under the "control" menu in the rule creator, did you check there?
Did you figure this out? I am having the same issue
Same issue, any update?
I had the same issue but after installing the Beta Firmware it works :-)
Are there any news regarding this problem? At my interface it still looks like on Sake Miedemas picture.
