Wall Plug turning off by it self
Not a Problem
I put my Wall Plug on my
fridge yesterday (it was on my comps) to monitor if the door is open. I had to
remove it from the dashboard and added it again because it was offline.
But now there is a problem
that the wall plug turns off (without me touching the button on top).
Is there something wrong
with the config?
I noticed the same behavour upon turning off the always-on device on dash board.
Then a off statement is reported in the event log and since always on a few min later it's reported as on.
It seems like the device is always on anyway. So the behavour seems incorrect in the log.
Hi Kristian,
Thanks, i think u are right because the power usage is still coming in (at the same time).
Offcourse Zipato needs to look at this/fix it.
May i ask for what u are using te plug?
Hi Kristian,
Hi Milan,
Thank u for the explanation. It makes sense.
Can u please answer this one to?
http://community.zipato.com/responses/fibaro-rgbw-controller-support
Hi Milan,
Hi.
I have similar problem.
I've tested three different wall plug`s which are working with other devices .... only not with freezer.
I constantly seeing that switch is switching on & off, but the freezer works always.
Also with settings > ALWAYS ON (enabled).
Is this ZIPATO issue ????
Some pictures are attached.
tnx again.
Hi.
tnx again.
