How do i connect wifi devices to zipato?
I have a 3 gang wifi switch that does not have zigbee or zwave or any protocols. it just connects to the wifi. i want to use this type of switches because it does not need neutral wire to work. just replace regular 1 line plus return mechanical switch and it will work!
how do i add this device to zipato?
is it possible to connect other wifi devices also like wifi smart plug or wifi smart light?
you need your switches to have an api or list of http commands that it uses. Then create a virtual switch within Zipato and use the rule creator to send http requests.
