Support for Home Easy 433MHz
John Rabbit shared this question 13 years ago
Is there any chance that the 433 MHz module is going to implement the Home Easy protocol? If so when can we expect that?
Replies (6)
Which HomeEasy devices are you looking to use?CoCo, KlikAnKlikUit and HomeEasy are synonyms most of time as the protocol is the same.
We haven't had any HomeEasy branded devices for test yet, but they should work without any additional work around the protocol part. Devices will be added to the list as we test them out. Meanwhile, you can try adding them as Coco devices with similar functionality.
If you're UK based, we're also supporting LightWaveRF devices.
Hi Tomislav,
Thank you for your response. However it is a bit more complex. After searching on the internet I came to the conclusion that there are 2 main HomeEasy protocols:
1. HomeEasy UK: most of the time compatible with KaKu/Coco/Chacon etc;
2. HomeEasy EU: used in Europe (not UK) and definitely NOT compatible with CoCo;
Unfortenately I am living in the Netherlands so I have the EU variant. When I try to join a transmitter (HE844A) nothing happens. The protocol is not recognized. I have tried it with different devices from chacon and coco with zero result.
You can have more info about the devices on http://www.homeeasy.eu or http://www.elro.eu.
For me: I hope that Zipato will implement this protocol in the future. Otherwise I have to find a different solution for this HomeEasy stuff.
John
Other than HE844A, which HomeEasy/Elro devices do you use?
Hi Tomislav,
Currenty I am using:
TX:
1. HE844A Remote control;
2. HE843: 2channel wall control;
3. HE842: 1 channel wall control;
4: HE8850: Timer control;
RX:
1. HE875; Build-in switch;
2. HE877 and HE878A: plug-in switch;
3. HE878: plug-in dimmer.
So quite a few,
John
Hallo,
also ich habe auch einen Elro HE889 mehrfach als Coco, Blyss.... Adapter mit der Zipabox verbunden. Gefunden wurde der Adapter auch, aber leider immer ohne Funktion.
Ich würde mich auch freuen wenn die HomeEasy Artikel für EU auch implementiert werden in die Zipabox.
Falls jemand noch einen Tip hat wie man die HomeEasy von Elro mit Zipabox verbinden kann so das Sie funktionieren dann her damit.
Danke.
Same for these chacon look like products. They are recognised but are not working.
i.e :
http://www.home-confort.net/fr/content/mmv-100-micro-module-de-commande-pour-volets-et-stores-motoris%C3%A9s
