RGBW Controller with switch
Hi Zipato,
I see that the configuration tab from the RGBW controller is updated. Great job!
But i got a problem with getting my switch (BI_STABLE) to work with the controller. What i understand from the manual that u need to config parameter 14.
I'm using this manual to get the right value:
http://www.domotica-shop.nl/files/images/Fibaro/ras-rgbw-controller-en%20NON%20HC2.pdf
I think i must use toggle with memory (brightness mode) thats HEX 7777 and the DEC value = 30583.
But whatever i try nothing is working. Can u please help me or tell me what i'm doing wrong.
Replies (9)
This device is still not fully supported. Most probably we will finish the integration within a next week.
Oke...then i stop with trying :)
More disappointment, how come open source can support products without paid devs but a premium commercial product is incapable weeks after release?
Disappointment?
Come on..give the guys a break.
The controller was released 4 weeks ago? but was hard to get. Zipato got there controller last week in there lab. So i think they are working very quickly on it.
And i don't know any open source product that fully supports it. And with full i mean with color wheel and all the parameters working correctly.
Please read all the posts related to this issue, you will be less disapointed and you will save a lot of time to all of us. Integration of this device is scheduled for the next week. We are not open source system, and once we do it, it will be done properly with the possibility to use it within a rule creator as well. Please be more patient about the integration of the new devices, which are available on the market for less then two months.
HeroS wrote:
Disappointment?
Available to consumers for four weeks, agreed the implementation is OK on this new class of device
Excellent, looking forward to full features of all devices available such as Minimote and being able to turn my dimmer on and off without affecting the brightness last set
Hello Sebastian, I am busy with the RGBW device to read the 10V inputs, I would like to read four temperature sensors.
I assume this is possible but I cannot get readings from the analog inputs. I have used 8888 for parameter 14 (100010001000)
How can I get this to work ?
And to the zipato team. Please also inform us if you work on a better integration of this device. On my side, I would like to be sure that a change made using a switch will be visible immediately in the dashboard as mentioned here:
https://community.zipato.com/topic/fibaro-rgbw-controller-support#comment-13141
