Fibaro RGBW - Questions/Bugs
Made this thread to ask questions and report bugs....
Replies (16)
First off >> Great that we can change colours! Now i can finally play.
Q01:
I got a RGBW ledstrip. When i change the colour to full red (0/0/255) the led puts the white led on (can't select the white on). So there is no full red (but mixed). Is there away to turn off the white led?
Q02:
What parameters to use when u have a normal light switch (BI-stable) on the controller?
Bug 01:
I have a fav colour Red (0/0/255) when i click on the circle (blue part) it changes then when a click again on the fav red colour it is not showing the right colour and position. I have to click again on the fav. red to get the right colour.
Bug 02:
Slider don't show right position when u click in the circle.
RDXpdalDbm37okFiNFix
Wish 01:
Can u make the circle a bit bigger because often i click in the square and not on the circle? Happens often with blue.
Bug 03:
When u click in the circle the bars and colour changes. Then when u change the numbers the colour doesn't change when enter the seconds number.
1kMENCyXPdulX3m1CA4C
Bug 04:
In the Android app the rgbw lights are not shown in lights and power but when i go to rooms they are there.
HeroS wrote:
Q01:
Now you can control white led.
HeroS wrote:
Bug 01:
I can't reproduce this behavior. Please post more information about browser, os, pc...
HeroS wrote:
Bug 02:
Can't reproduce. Post more information.
HeroS wrote:
Bug 03:
Also can't reproduce.
Do you experience this problems all the time or is it just sporadic?
HeroS wrote:
Wish 01:
No, circle is now on it's maximum size, it can't be bigger.
Hi Nenad,
Fast reply! Thanks
The wit is working now. Great! Now i can make real red :)
Also i tried to reproduces the above bugs and all are solved maybe the white was causing the problems?
Only the Andriod bug (04) remains.
Bug 05:
When i add a fav. colour the white colour position is not saved.
So when a leave the panel and turn it off and then on (white is full) then run a rule that turns the light on fav. colour Red (#ff0000) it mixes with the white. So there is no full red.
Rule:
KgRB86rxyic7SVFrm8D9
I think that when i use the RGB in the rule creator u should only use the RGB leds when u use the RGBW in rule it should use the RGB and White colour.
Also this problem is in the colour pop in the dashboard.
(windows 7 (64bit) NL - Firefox 22)
Can u please answer this question:
Because it's not working. Switchting on works fine but off is not working (i have to switch on/off several times).
I put all 4 wires from the input into 1 wire on the switch.
Answer for Question:
Set parameter 14 to 21845 (all inputs set to TOGGLE (BRIGHTNESS MODE)) to work with bi-stable
Thanks zipato!
Bug 05 >> is also fixed! Great!
