How to launch a scene when toggle multiple time a switch
Michael Barbezat shared this question 13 years ago
Is it possible to launch a scene when toggle multiple time a switch? ( ex: 3 time in less than 3sec)
Could you explain me how to do it?
Thanks for your help!
What kind of switches do u have? and what kind off devices do u use?
I'v 2 types of modules :
- Chacon DI.o double
wall switch
- FGS221
"Switch 2x1,5kW"
Michael
I can't help u.
Don't think it's possible u can make a rule that checks the status off the lamp but u don't want it to run all the time.
Here is an example. If the switch of light is changed twice quickly (into 2 seconds)... the roller shutter will go up.
In order to do that, I have used a variable: That variable is set to 1 only 2 seconds after the first time, In that case, if the swich is pushed again, you can execute other action.
Files: ex1.jpg
