NEST with Zipato?
HeroS - www.domotica-blog.nl shared this idea 13 years ago
Replies (30)
NEST in Europe??? Waiting for it for so long.....but Netatmo will release their own thermostat soon! (working in EU)
I have already the Nest Protect smoke and carbon monoxide alarm and working great
My NEST is coming this week :)
Can someone please make a script because Zipato is not going to support this devices very soon.
Would be nice to send a http request to google script and then use the API to change things on the NEST.
For the otherway around i can use IFTTT and google drive (http request to meter).
A script could be nice, but i hope Zipato add support for these devices. So we can add them directly to the zipabox.
I would be great to use de motion detectors of the Nest smoke detector or thermostat directly in rules and see them in the dashboard under devices, sensors and meters.
I totally agree with you. These kind of devices should be prio voor Zipato. HC2, Zibass, Vera and Smartthings support NEST.
But i don't think Zipato is going to support NEST but if they come with some sort of IP support then other users can create something.
Hey HeroS
I just installed my Nest... any news about a script or workaround?
Hi Thomas,
Not working on a script...i'm not that smart ;)
But i got somethings running in IFTTT.
Temp Nest >> IFTTT >> Google Drive >> Zipato virtual meter
And working with Tasker to change the temp when i'm away. But this is not working yet with more then 2 people.
These are just dirty workarounds. Zipato just needs to support this devices or make a good connection to IFTTT.
Check this:
https://github.com/gboudreau/nest-api
It is working, you simply need to host the files and create one php per command.
I don't see how to get the data (send a http request) to the zipabox.
Do you have a working code?
You can set away or home mode and set temperature
example to set temp to 19 : (you need to have nest.class.php in the same folder as the php file used to launch the command)
<?php
require_once('nest.class.php');
// Your Nest username and password.
define('USERNAME', 'xxxx@xxxx.com');
define('PASSWORD', 'xxxxxxxxxxxxxx');
$nest = new Nest();
// temp 19
$nest->setTargetTemperature(19.0);
I see...give it a try.
Thanks!
Great! got it working on a virtual thermostat.
Just need to make it safe with a password on it.
create .htaccess in the same folder with this inside:
Order Deny,Allow
Deny from all
Allow from 192.168.0.X/255.255.255.255
where X is the ip of your zipabox
Good idea!
Thanks!
How did you configure the virtual thermostat?
edit: I may create a virtual swith for home/away and heat on/off and the use it inside a thermostat
4
Hello Zipato developers,
I think that you need to speed up this development because now the eedomus box support the nest products ....
http://blog.domadoo.fr/2014/11/13/eedomus-support-produits-nest-nodon/
kr,
Best regards
I wait
I want
Yep - bring it on ;)
Yes please
+1 please
Yes Please
Add my name to that list too.
me too!!
I'm interested too in this matter... Please, embrace integration with Nest!
I was under the impression that any z-wave device is supported right out of the box? Isn't that the point of having the same protocol etc....... It is a bit annoying that whenever something gets released, it isn't supported unless Zipato decides to support it?
Nest doesn't use Z-Wave, it uses it's own Nest Weave protocol over 802.11 b/g/n and 802.15.4 (which Zigbee uses for its low power mesh network). Zipato has to use Nest API's to integrate it in to the Zipato wider solution. No easy fix unless they do a bit of work ... which I'm still hoping they see the value in doing so!
Welcome to the world of z-wave.
This morning I was playing somewhat in the control panel and saw that you can buy NEST integration as an additional service.
Fore a mere $59. :(
That's a service or an expansion module (such as the one for ZigBee) ?
Thank you
A service
This is a real shame (understatement). At Fibaro it's possible without paying extra (if I'm not mistaking) and here we have to pay 60$ (yep because we have to buy a package of 50 + 2* 5 credits)...
Not happy at all. Probably will go a different route if this continuous. This was one of the next big things I was waiting for but it seems all the new features will be payable...
Hey you bought the car... Cool but now pay for the wheels otherwise you can't drive... and while you are at it pay for the steering wheel otherwise you can't steer...
I have a strong opinion about this but I'll keep it for myself...
"Keep up the good work guys"....
Hello everyone, I'm the only one who has problems with NEST and zipabox? the connection between the box and the thermostat works randomly.... :-( it's been over a year since it lasts
