Rule not working >> Variable ignored?
Hi Zipato,
I got this rule:
I want to todo the following:
IF
PC = on or PC power > 100
Then Speaker ON
IF PC = Off or Pc power < 25
Then Speaker off
When the pc and speakers are off i don't want it to keep turning the speakers off. So i set a variable at the end.
But it keeps turning the speaker off. I have done some testing (E-mails are coming in) ...i think it ignores the variable pc speakers.
Log:
Can u please help with this rule.
Your IF condition with speaker variable is wrong.
Remove everything and leave just 'speaker = 1'
Also note that all of your IF conditions will be executed when you turn PC on and your PC current consumption is lower than 25 (didn't get a chance to update).
Maybe it would be better to use operator AND in first and second IF condition.
Hi Nenad,
Thanks! I got it working but had to make 2 rules.
Hi Nenad,
I'm glad you get it to work.
Sometimes it's better to keep it simple and split complex rules :)
