Problem with date of synchronisation
HelloI have problem on my zipabox with date of
synchronisation. I synchronise the box by using the button on the
dasboard but the date is always on the old date of synchronise when i
refresh the dashboard. Why? Is it a problem or normal work?
I have unplug Zipabox from power supply, and plug it back again but it' the same
It do not work since the last update 0.9.988 . I synchronise but the date is always the same , an old date, when i refresh the dasboard. And i have no feedback of all my devices !!!
No news !!
No news !!
Hi Chris,
Try this:
>> Dashboard
>> General setting
>> Zipabox setting
>> Time >> select right time zone (if it is in the right zoen just select again)
>> Save
>> Sync
Please let me know if this works. And also if it doesn't work send mail to support@zipato.com
Hi Chris,
Try this:
>> Dashboard
>> General setting
>> Zipabox setting
>> Save
>> Sync
I tried that but it do not work. The synchronise date is always the old date when i refresh the dashboard
Better contact support@zipato.com
I do that but the response of my email is : Your ticket has not been accepted into the system. This is the support desk for the active Zipato users only.
Fill in all the fields in the >> General setting >> Details >> Save >> Sync.
And use your email that you use to login to the box.
Another thing u can try...
Disable all your rules and try sync again.
hello
You can close this problem, the problem is due to the ethernet cable.
Thank for your support
Christophe
hello
Christophe
