decrease and increase function in a rule
laurent dartiguelongue shared this question 12 years ago
hello,
I wanted to know how the rule worked with virtual dimmer, the INCREASE and DECREASE function. because nothing happens when I create a rule with these conditions.
thank you.
Can you post the rule?
Increase is action event and it will be fired only if you have some other rule that is initiating Increase action. If you want to trigger this rule by changing dimmer value than you should use Attribute event (Intensity) or Action event (Gotovalue).
thank you, I knew how.
