Product "Philio Tech"
Does the product "Philio Tech" are integrated on the zipabox?
Thank you for your feedback
Nicolas
Very nice products! Do you know where u can buy it?
yes here: http://store.zwaveeurope.com/
But you need a company to buy on this site.
Where you from ?
Where you from ?
The Netherlands
The Netherlands
It says:
Note: The illumination sensor does not work with Fibaro Homecenter 2 and Zipabox yet.
It says:
They are very serious and are located in Germany
and I make a mistake not need a company to buy from them ...
ah... ok thank you ! just the fonction illumination or all the module...
Are u going to buy it? Please let us know if it works.
Thanks!
Thanks!
yes I think the products are interesting! I give you a feedback
Zipato team, what do you think about?
The products looks interesting. We will add them within a week or two...
Great Sebastian!
Great Sebastian!
Yess ! thx you Sebastian
Did you add devices to Zipato?
They use Zwave 400/500 chip series so you get the last tech.
http://philio-tech.com/
p.m. Sebastian do you have any relative in Turkey?
And is full support there? i'm about to order 4 of them :)
What is the status of the support for the sensors ?
I would like to order them too !
From support:
We are currently supporting following from this manufacturer ( those devices we
have in our lab ):
1. Philio PAN04-1, PAN06-1 in wall modules
2. Philio
PSM01-1, PSP01-1, PSM02-1, those devices have the same device identifiers so
they will all have the same name when added to Zipabox
Other devices are
not supported for now.
From support:
have in our lab ):
2. Philio
Other devices are
is it already in the 991 firmware? i'm receiving my zipabox and PAN06 and PSM02-1 sensor.
ok, for now. Im using firmware 993. sensor is detected with a generic zwave.
only the magnetic sensor is not showing. I read in the manual it has to be set through the zwave configuration. default settings for the magnetic contact is off. but no option in the zipabox to configure it. all other options are working (motion, temperature, lumen)
Hi Gratje,
You can add custom parameters at the config tab but i don't know which parameter u must use. But this must be in the manual.
Hi Gratje,
it is a philio tech psm02 sensor.
http://www.robbshop.nl/lanotattachments/download/file/id/134/store/2/phi_psm02_compressed.pdf
There's some text missing in the PDF.
But i think:
Parameter: 6
Value: 3
But i think:
Parameter: 6
Value: 3
and how do i fill this in the configuration? can I read out what the current setting is of a parameter?
don't understand the part:
when Bit2 is 0 (enable), the device is installed in the same room with the light?
0: in the same room (default)
1: in the different room
Bit 4: Disable delay 5 seconds to turn off the light, when door/window closed.
Bit 5: Disable auto turn off the light, after door/window opened to turn on the light.
notice: If bit 2 is zero, the setting is useless.
can you set more bits in one parameter?
small update about the sensor again.
motion sensor is laying at home. nobody is home. motion sensor is not sending any statements. last time was 7.05 AM. and it did say the motion sensor is triggered. And it is not turning off. I know there is nobody home. but the psm02 sensor is not sending its status to the zipabox.
ok, made a ticket for support. I've been in contact with philio tech, and they want to help to solve the problem together with zipato.
I made mistake when i was writing support for these devices. I failed to notice that these device use a Z-wave command class (binary sensor v2) that we don't currently support. That's why you can't see your door/window sensor.
I am very sorry about this.
Support for binary sensor v2 will be added early next week and then i will personally update your box firmware.
Marko,
this makes me very happy. played around a bit more. and it looks like the door/window snesor is working. but it is switching te same statement as the motion sensor. so at the moment motion sensor and door/window sensor are shown as 1 sensor in zipabox.
I also saw the wake up is version 2. will that also be fixed?
Marko,
hmz. strange. since yesterday I have complete different events in my ssensor.
before I had temperature, luminance and motion.
not I have state and value1 and value2.
and the meter in the control center is not showing anything anymore.
Same here....they must be working on it.
HeroS, Just got a report from support. my box is updated to 993d. need to try it out tonight.
Thanks for the update.
Here is an update again.
for my part, door sensor and motion sensor are seperated.
more parameters available.
had to remove and re-add the device to get the new settings.
but sensor keeps going offline.
and it looks like if i adjust something in the configuration it will not be adjusted.
Sometimes it the takes awhile for the devices to be found again. The zwave connection has to rebuild.
Also when u remove something first do a remove, reset and then added it again.
Looks nice! But can someone tell how a motion sensor AND a door sensor are useful together? If sensor is open i expect motion... What am i missing?!?
- Extra check in your alarm panel (follow up)
- To detect motion in the same room
- I have a rule that when i open the door the light in the hall goes on. But when i'm leaving the hous the light also goes on. This is not what i want. With the motion on it i can detect when i'm in the hall and then turn on the light.
I can confirm the PSM02-01 4in1 sensor is working properly with latest firmware 995.
Hi Geert,
Do you have any problems with the device going offline sometimes?
Hi Geert,
I have two PSP01 muli-sensors. Recognised by Zipato as two sensors: one motion, and one temperature + luminance combined (why not separate?).
One is the input for a virtual thermostat with a radiator as an output. It worked fine while there was movement, but when people sleep and don't move then it stops reporting temperature and the radiator never gets turned on, and the room gets cold.
How can I force the PSP01 to always report temperature throughout the whole day?
I have more information after contact with Philio and Zipato support.
The Philio multisensors, although they do carry a temperture sensor, are NOT well suited for heating control, such as in a Zipato virtual thermostat. This is because they only send a temperature report at most only every 30 minutes and only if there is a temperature difference >= 3°F (1.66°C).
This is too course for heating control in most situations.
Otherwise these are very cute and well-built miniature devices!
Further, there are some discrepancies between the Philio documentation and the Zipato config page (params, bits). Zipato is looking into this...
Regards, Nick
Regards, Nick
Greetings,
We have changed the default value for configuraton option nr. 6 (multi-sensor function switch) from 0 to 4, which is the default value for all three models. We have also removed the duplicate bit5 from that same configuration option.
Greetings,
Hi Marko,
Removing the duplicate bit5 is not the solution! The duplicate bit5 should have been bit6, for activating the temperature monitor which is what I need.
See http://www.pepper1.net/zwavedb/device/477
For me the situation is worse than before you "fixed" this, because the previous (invisible) default for bit6 was 1, which provided me with the temperature reports that I need. Now you have put it to 0 without any way to change it. Now I have stopped getting temperature reports.
Also, you should allow the user to overrule the named options with custom parameter values. Now when I put 6 in the custom parameter number, it has red error "Parameter already exists" and saving is not possible. It should be a warning, still allowing saving. Then this situation will never exist again.
Hi Marko,
We stand corrected, bit6 is now present in the configuration option.
Marko, thank you so much!
However, what do I have to do to access bit 6?
I reapplied device decriptors (not exactly sure what that does).
After emptying the browser cache and reloading (is that necessary?) my two identical sensors give different config screens, and the duplicate bit 5 is back again for one of them:
Now suddenly I' am seeing bit 6. Did I do something or did you? Vague...
I am unable to add this device (Philio PSM02 4-in-1 sensor) to my network. Can anybody help me please?
I put zipabox into add mode, click the button inside the PSM02 once, but nothing happens. Also, I put zipabox into add mode, click the tamper button 3 times and nothing happens as well...
Desperate... The only thing I have managed to add to my network until now are fibaros swithes... is it me or is it zipabox??
i noticed that you have to put the sensor real close to the box to get it working.
I have managed to add the Philio to my zipabox.
But now I have another issue:
The sensor is not communicating state to the zipabox, or at least I'm not seeing any events and therefore not actuating anything. I have the DIP Switches in Test Mode (Both ON) and when I separate the magnet from the sensor, or approach it, the led flashes to aknowledge detection. So the sensor is working, no doubt, at least the magnet. But no events on zipabox. The same thing goes to the light and motion sensor, no events either.
Is it lacking further configuration? Is it malfunctioning? Can anybody show me how they have them configured on zipabox?
Thank you and a happy Easter everyone
Thank you Sebastian, but I have not been able to locate that button "RE APPLY DESCRIPTORS".
I think I have been all over the Control Center looking for that. Where can I find it please?
Thank you again
Thank you again
Look here: (top level)
If you don't see the button as on the photo from HeroS, then you need to join device again.
Greetings,
Ricardo, your Philio sensor was not properly autodetected. Now it should be displayed correctly on your dashboard. But yes, it would be best if you would simply rejoin the sensor.
Greetings,
I have a PAN11-1 switch
Add device ok.the switch works.
But no energy meter.
Has anyone here tried the PSR04 switch?
I cannot get it to work with dimmers, only on / off switches. Also: it seems the support on zipabox is limited.
