ESPEasy (ESP8266)
Sean C shared this question 7 years ago
Has anyone had any success with sending data (i.e. Temp or Humidity) from an ESP8266 device yet? I have 4 extractor fans that are run from Sonoff TH16 flashed with ESPEasy. They work beautifully with Domoticz but I'm trying to get all my devices to work under one umbrella.
Any ideas? I'm currently looking at SendtoHttp in rules but I think it's failing due to https
Many thanks
Sean
In the past i had some devices running ESP8266/ESP32. For temperature/humidity/air pressure etc. I don't know ESPEasy.
What I did was quite simple: use the wificlientsecure class to setup a https connection with a zipato virtual device. That is all you need to set a value.
