Add geofencing to the iPhone mobile app
Pascal Verstappen shared this idea 11 years ago
Planned
By adding geofencing to the iphone app you can create actual presense events. It will be possible to create true leaving and arriving events.
Replies (13)
I have already asked for this. Its not in the dev. plan.
Thx for your reply - too bad however.
Have you managed to find a proper workaround for this?
I'm using Automated Pro for this (Android).
But look here:
http://domotique34.com/geoloc-lapplication-iphone-quil-vous-faut/
There are more solutions for this..just google.
And i use the App Depart for Ios.
Hello, whats the specific IOS app u use ?
You can use ifttt. See knowledge base how ifttt works with zipato.
I tested IFTTT on andoid, but geofencing seemes to be a little unreliable, sometimes it worked, sometimes not,
I joined IFTTT+MAKER channel with a virtual meter on zipabox. A sub-Meter for each person, one sub-meter for total. A rule that recalculate total on every people meter change.
Ifttt on each phone, that make a call that change the meter to 1 if inside the geofence, 0 if outside.
I'm trying to do the same thing but can't get it to work correctly with the rule creator. We ar two people and I want to run a rule when both have left the house and not make it run if one person leave before the other one. And when one person comes home a rule runs but if the other person comes home after the first person then no rule/scene runs only door lock opens. I would love some help if it's possible. We each have an IFTTT account and a location recipe with a virtual meter each in zipabox with value1 at 1 for home and 0 for not home.
Thanks!
Hi ..
Try this, it is working for mea145a560edcbddf5e028c9004e728b66
Guys, instead of Virtual meter use virtual sensor. This way you can use the "and" puzzne in the armaway and "or"cf6210d1648bcc05aec4b17d8b409098 puzzle in the disarm.
Atilla,
could you please explain something more to Variable and value 100 ???
I did create variable RESTART, what now ???
TNX.
Oh, yeah, you are not aware of the other topic. It is a little long, but it helped some of us to get more stable system...Restart variable is a variable that will notice me every time my zipabox restarts (regardless if I restart it manually or it restarts due to system shortage on flash memory. Either way when I receive the restart message i know that my zipabox is fresh and ready to work. This restart variable I have in evey rule that has some tricks, so these rules will not start if the variable is not ready. In other words when the controller is not ready.
And the stop puzzle is just there as apparently it can also make a difference to stop a rule with a puzzle at the end or to let the rule be stopped by itself.
https://community.zipato.com/topic/zipabox-restarts-without-apparent
As to the rules i attached here, they work like a charm 100% of the time.
So the tpoic is here, have a good reading.
So the topic is here, have a good reading.
Thanks for all your help. I changed my virtual meter to a sensor and tried to build some rules. I'm pretty new at this so it would be great if some of you see some mistakes in the screenshots below and give me some pointers :)
What I tried to accomplish in the geofence rules are:
AWAY
(rule 1)
- When both sensors read "inactive" turn off all lights, set alarm and lock door lock if time is before 5pm.
c2cbb0bc0fa02e6769010bb28c95ecf7
(rule 2)
- When both sensors read "inactive" keep some lights on, set alarm and lock door lock if time is after 5pm
3bb7b24463a6dc345218cafe75b4b713
HOME
(rule 1)
- If one of the virtual geosensors read "active" unlock door lock and disarm alarm, but only if no-one else is home. If someone is already home only unlock door lock. And if time is before 5pm
816e20d81363d8798bd5ed64abbe388e
(rule 2)
- If one of the virtual geosensors read "active" turn on lights, unlock door lock and disarm alarm, but only if no-one else is home. If someone is already home only unlock door lock. And if time is after 5pm
e48e4e58862c2ca499a629e5de93e4c1
Thanks again for helping!
Simone,
Life360 (iOS, Android & WinPhone) is pretty good at GeoFence, and they do have a channel to IFTTT. Using this channel it would be possible to trigger both on individuals and on "last family member to leave" and "first family member to get home".
Brgds, Robert Hercz
Hi Simone, sorry for the ignorance, but can you explain/elaborate on your solution for your Geofence setup?
Thanks!
Hello boys.
I have set up an alarm system that will generate status after my current location and it kinda works, it can not turn on / off alarms. When arming / disarming the alarm it seems like it miss the username and password. how did you solve that ?
I´ve got the same problem and opened a ticket for that. Seems as if only arming is concerned. Disarming works if executed by a rule. I´m going to try it with "fast arming" tomorrow but I think if executed by a rule it should work even without fast arming. The missing username (first and last name) is a known problem and at least with 1.0.17 it worked nevertheless. Think thats a problem with 1.0.19
Hi Jonas,
I just tried it out: With "fast arming" selected (hope the translation is correct, in German it is "Schnelle Scharfschaltung" the rule can activate and deactivate the alarm. The username is still missing in case of arming the system while it is there when disarming. But nevertheless it works, even without the name.
Hello Klaus G.
You my man is the hero here :) it worked with Quick arm, i didnt have it enabled thank you
;-) I think its a bug in the firmware. Quick arming makes it possible to arm/disarm a partion by using a simple switch without username (so you don´t know who turned the alarm on or off) If it´s activated by a rule it should work without quick arming because it´s done by the system. It already works with disarming so arming should work too. But up to now we have to use quick arming when switching the alarm on by a rule. I´ve opend a ticket so I´m sure they will fix it with one of the next updates.
