My rules with scheduler doesn't work
Benoit D-F (fr) shared this problem 12 years ago
Hi Zipato,
When I use the scheduler in rules, it is OK with the first rule but the other rules are working with the same programmation than the first scheduler and not with the scheduler of the good rule...
Can you tell me if I don't do the right thing ?
Kind regards,
Benoit D-F (fr)
Replies (9)
Can u post the rules?
Hi Heros,
Here are my rules.
The first rule is the first rule that I have doing with a scheduler and is OK. It does an URL request hourly to do the Karotz saying the hour with Open Karotz.
The second rule is to do the Karotz sleeping at 22h55 dayly and it is not OK because it is making sleeping the Karotz at all hours (like the first scheduler).
Kind regards,
Benoit DF (fr)
Did you create a totally new rule for the 2nd one?
Or did you use some parts of the 1st rule and then modify them?
As tu réutilisé le capteur "programme" de la 1ère règle en le déplaçant sur la case WHEN de la 2ème?
@Benoit D-F (fr)
Try putting some email messages in the rule to see if the rule runs. Maybe there's something wrong with the http request.
Hi HeroS and Thomasfr,
I deleted all my rules with the scheduler and I have recreates them without taking pieces of other rules and they looks OK now.
Thank you,
Benoit DF (fr)
Oke great!
I found out that there is a bug when you take a scheduler from a previous rule.
It keeps the same settings even if you modify them.
Great to hear that your rules now work properly!
It's not a bug. Once you create a rule with scheduler, that scheduler is saved as separate entity and it have it's own name and id. When you are reusing scheduler from previously created rule and edit settings, you also edited scheduler for previous rule because it's the same one. Same thing would happen width the message puzzle. All other puzzles should be safe for reusing.
Wow!
That really helps to understand how to use the scheduler.Thanks!
