IPhone local rejects username and password
Garry Sherriff shared this problem 12 years ago
Remote works fine but local rejects username and password.
Are there any extra steps to enable local access?
Thanks!
Replies (7)
I have the same issue, have you found a solution?
Hello Krister, this is a three months old post. This problem is solved already, so your problem should be something different.
Are you using Android or iOS?
Yes i saw that.. nevertheless i have the same issue.
I'm using iOS 7.
I select Local on the app and the local name changes to Scan.
Below the Scan I see my local zipabox, when clicking on it, I get the username and password fields.
I enter the same username and password that I use in remote mode and click on Connect.
It says connecting for 2-3 seconds and then it says " Username or password is wrong"
Hi Sebastian, I don't see a solution posted - can you expand on how to solve this? Thanks!
I can't login locally with android and iOS
Hi all,
I remember that a few months ago I did experience this same issue.
At the time I noticed that the login is not case sensitive in remote mode whereas it is in local mode. I put everything in lower case and then it was OK for both local and remote auth.
Did you check that the login field does not start with a upper case letter?
I can't login from android as well. Tried with all lower case as well but does not work
