Android App only WIFI ?
Ludovic shared this question 12 years ago
Hi all,
I'm new on this community and I warn you my English is poor :-)
My question is in the title ! I can't log on the android app when i use my 3G connection "Erreur lors de la connexion. Veuillez recommencer.". It's normal ?
No problem on WIFI.
Thanks for your response,
Ludo
Et si par hasard vous vouliez me répondre en français, n'hésitez pas :-)
Replies (11)
Sound like a firewall/port problem.
Can you acces the dashboard outside your network? (on PC)
Hi HeroS,
I can access at my.zipato.com outside my network with a PC (box is online), i can access with my phone (android app) with any WIFI (inside/outside my home network) !
I can access in 3G at my.zipato.com (not very usable).
Only android app in 3G not working :(
Strange...what version are u using?
Latest:
http://files.zipato.com/Zipato_2.0rc12.apk
hello. nobody has a problem closing with this version? no update planned?
Latest:
I have installed last version now and works fine...on WIFI :(
For Yves what problem for closing ? Disconnection is ok for me and after android do his work.
Maybe solution here:
http://forum.xda-developers.com/showthread.php?t=1601681
@Yves >> Zipato is working on a update.
Pffuuu no proxy configured on my phone :-(
But thx for your help HeroS !
What phone and android version do you have?
Also try >> erase data and buffer >> then remove app >> install new one.
Hi HeroS,
My phone is a Sony XPERIA U - Android version 4.0.4 (and no official update available).
I have tried >> erase data and buffer >> then remove app >> install new one >> for same result --> No connection
Today, i have installed zipato android app to a coworker phone (Nexus 4) and no problem to connect to my box in 3G !
Should I buy a new smartphone??
Thank you again HeroS :-)
check if you have any typeof antivirus/trojanscanner/firewall installed on the phone.. like avg and similar.
If yes, try to temporary disable it and try again with the zipato app.
I think it's not an app problem.
The coworker phone is on the same operator? If yes, are you using the same apn?
Are you accessing the net through wap apn ? sometimes wap apn block direct connection to specific ports..
Hi Mr Biagini,
I can't find firewall,antivirus,... installed on my phone.
My coworker is not on the same operatot :(
I don't understand WAP apn !
If it's help you, my phone is configured like this :
APN : mworld.be
Proxy : Non défini
Port : Non défini
Nom d'utilisateur : Non défini
Mot de passe : Non défini
Serveur : Non défini
MMSC : Non défini
Proxy MMS : Non défini
Port MMS : Non défini
MCC : 206
MNC : 10
Type d'authentification : PAP
Type d'APN : default
Protocole APN : IPv4
APN activé
Réseau : Non spécifié
