Impossible to unarm alarm
Vlad Vroonen shared this problem 12 years ago
Hi guys,
It seems it is impossible now for my to unarm my alarm. If I try to do it with your website, I can not get in the alarm module, although my code is correct. It doesn't give an error.
When I try to connect with my iphone, the security module gives my the error time-out after entering my code...
What can I do? I can't leave my home without tripping the alarm...
Thx!
Replies (9)
Please, send me your credentials hello@zipato.com to check out what is going on
Same problem here >> Can't access the alarm widget >> I'm sure that the code is right.
@Vlad
Do you have the quick arm option on?
If you do.... try making a rule to disarm the alarm with an switch.
Same problem here for 3 Zipabox.
regards
Working on it...
Sebastian Popovic wrote:
Working on it...
Great!
HeroS wrote:
@Vlad
Disarming with a virtual switch and a rule worked! Hi Freedom :p
I read somewhere that disarming was impossible with the rule creator, but that seems to be working fine!
Thank you for your help Sebastian :)
Good luck with this!
We stay tuned.
It should work now.
we had some problems with the message queue which was causing the problems in communication between the server and the UI.
I used this tool to calculate my Calcular RFC with homoclave, and it was fast and easy to use. The interface is simple, and the result was generated in just a few seconds. I also liked that it lets you verify the RFC using the official SAT format, which adds confidence in the accuracy. It's a helpful tool for anyone who needs to calculate or validate an RFC quickly before using official SAT services.
