Http request with JSON Payload
Chiquito shared this question 12 years ago
I'd like know if it's possible to add a Json payload in a http request?
I want use a API of a third party device that use JSON.
My Json command have some parameters.
For my test i use "Advanced Rest client" chrome extension.
I put my url : (http://192.168.1.254/api/v1/lan/wol/pub/)
I choose "post" methode
I put my parameter in the "payload" field" :{"mac":"XX:XX:XX:XX:XX:XX","password":""}
the request succed.
I tried to put this parameter in header or body field but does'nt work.
i tried as well to encode the payload and put an url like that
http://192.168.1.254/api/v1/lan/wol/pub/%7B%22mac%22=%22XX%3AXX%3AXX%3AXX%3AXX%3AXX%22%2C%22password%22%3A%22%22%7D
it does'nt work neither
Thx
Try putting this into headers:
  1. Content-Type: application/json; charset=utf-8
  2. Accept: application/json, text/javascript, */*; q=0.01
and with JSON in the body.
I tried but nothing hapen.
This is a screenshot of my request.
But there is anyway to debug it.I should post an idea to get a advanced debugger to analyse http request for example or variables in rules...
I tried to debbug with wireshark but unreadable for me.
Files: WOL.png
If you want to wake up a computer and have a webserver or NAS this easy to do.
go to: http://sourceforge.net/projects/wolviaphp/files/wolviaphp/version%202/
Once you "installed" this website you will be able to do a WOL if you follow the procedure. Once you waked up your machine you will be able to Bookmark this URL to repeat this WOL-request.
Create for example a virtual switch an d create a rule:
When Virtual Switch Power On PC is ON
then
HTTP Request using method PUT with the URL you just bookmarked
