Greenwave power node NS-210 support
Theo van den Dolder shared this question 12 years ago
I installed the Greenwave power node NS-210 as generic Z-wave device.
The power node is visible under Meters - Sensors and Lights and Power
  • On/Off Switch part is working under Light and Power.
  • Meters: no values visible
  • Sensors: as far as I know it has no sensor
Is this power node supported?
Replies (11)
This one is supported:
http://www.nuonenergiewinkel.nl/7591/smart-plug-6-voor-nuon-e-manager
But there are some problems. Zipato is working on it.
I have the green wave smart plug 6 already in use for my AV system. Nice adapter!
Support for the NS-210 would also be nice. (reasonable price for adapter with power meter)
It does have sensors. Read it somewhere, in their patent filing I think. It has physical sensors for knowing when a plug is actually plugged inside each socket, or if it is empty.
I thought de sensor was implemented for the track wheel/room selector.
In my opinion greenwave has implemented a unnecessary option for room naming/location.
I hope that Zipato can block that option/sensor like they did with the power node 6 earlier mentioned by HeroS. This device has also the same track wheel but in the device manager it shows no sensor.
The power node NS-210 is now supported. De sensor is removed from the firmware. @Zipato my question is answered.
that greenwave smartplug 6 is cheap...... 49 EUR. I have the greenwave powernode 5 plug and that costed 75 GBP....... :(
Also, it most likely uses the firmware of the euro 6 socket version as it only has 5 sockets, but in Zipato I see 6 :-) and 6 meters.....
310a5a9b9054182b084840f00cd1de73
Just a question, I've read in an other community post that only first power meter works correclty: is it fixed now?
Any new about the 6 power meters ?
I have eatch power meter return to the box, but sometimes with some delay (compared to Fibaro wall plug for examble). And only one parameter not realy usefull.
thank you
