Greenwave power node NS-210 support
I installed the Greenwave power node NS-210 as generic Z-wave device.
The power node is visible under Meters - Sensors and Lights and Power
- On/Off Switch part is working under Light and Power.
- Meters: no values visible
- Sensors: as far as I know it has no sensor
Is this power node supported?
This one is supported:
http://www.nuonenergiewinkel.nl/7591/smart-plug-6-voor-nuon-e-manager
But there are some problems. Zipato is working on it.
Support for the NS-210 would also be nice. (reasonable price for adapter with power meter)
It does have sensors. Read it somewhere, in their patent filing I think. It has physical sensors for knowing when a plug is actually plugged inside each socket, or if it is empty.
I thought de sensor was implemented for the track wheel/room selector.
In my opinion greenwave has implemented a unnecessary option for room naming/location.
I hope that Zipato can block that option/sensor like they did with the power node 6 earlier mentioned by HeroS. This device has also the same track wheel but in the device manager it shows no sensor.
The power node NS-210 is now supported. De sensor is removed from the firmware. @Zipato my question is answered.
review of NP-210F
> http://blog.domadoo.fr/2015/05/25/guide-dutilisation-de-multiprise-z-wave-greenwave-zipabox/?utm_medium=feed&utm_source=FeedPress&utm_campaign=Feed%3A+domadoo+%28News+Domotiques+by+Domadoo%29
review of NP-210F
that greenwave smartplug 6 is cheap...... 49 EUR. I have the greenwave powernode 5 plug and that costed 75 GBP....... :(
Also, it most likely uses the firmware of the euro 6 socket version as it only has 5 sockets, but in Zipato I see 6 :-) and 6 meters.....
Just a question, I've read in an other community post that only first power meter works correclty: is it fixed now?
Any new about the 6 power meters ?
I have eatch power meter return to the box, but sometimes with some delay (compared to Fibaro wall plug for examble). And only one parameter not realy usefull.
thank you
thank you
