Chacon LMDT-609 (54503)
Gael Poffet shared this question 12 years ago
Has someone been able to use the motion detector Chacon LMDT-609 (54503) with Zipabox ?
Thanks for your feedback.
G
Replies (6)
You can try to configure it as a Nexa LMDT-609 device. Same device, same protocol.
When I try to add the Nexa LMDT-609 device the device adding process stay in "Starting ..." mode. The countdown never start. If I don't wait the countdown and activate the device to send the learning command nothing happened :-(
Any idea ?
Yes I do,
Same thing for the switch. I think they forgot something to implement. The same happened when the 433 module was introduced. Best thing you can do is to go to http://support.zipato.com, file a ticket and tell them that the countdown don't stop.
No, Nexa devices cannot be joined yet. Entries have been added to the GUI but you cannot join them with the current firmware. Full support for all the Nexa devices listed in the "add new device wizard" will come with the next firmware.
But for now, you can join this motion sensor as a "Chacon CAMDT-1010 indoor motion sensor".
Thank you, it's appreciated.
Ok, thanks for the info
