Clearing accumulated power consumption Everspring AN158
Frederic P shared this question 12 years ago
In the manual of the EVERSPRING AN158 (On/Off module withe mesure of consumption), fully supported by the zipabox, to clear the accumulated power consumption I'll have to send :
Meter Reset Command: [Command Class Meter, Meter Reset]
How could I clear the value or send the meter reset command to the device ?
Thanks for your answer.
Fred
Ok found.
Go to the device manager and reinitialized the device.
Can you give me the steps to follow?
I can not find how to reset these device :-(
Thanks.
Currently, Is is not possible to send a meter reset command from the dashboard.
However, a factory reset procedure is documented on the first page of the manual, have you tried doing that?
In device manager, if i use "Re-apply device descriptors" button, the accumulated power consumption is cleared.
Thanks.
"Re-apply device descriptors" didn't work :(
is there other way? Does anybody know?
